Hi guys. I thought i would show you little idea i have done to my mardave
If any of you use foam or rubber blocks under the rear pod to stop it moving about alot. thought this might help?
not only does it stop all the mess from the wd40 squeezing out the foam or rubber' but it let you control how much movement you want from the pod.
I used a small hot screwdriver and put 2 small holes in the pod and then screwed 2 small screw's in to it
myself and ryan have been driving the car with the screws in at hinckley and you can tell the difference. i have got it set at 3mm at each side if that helps anybody.
