Here's how you can do it if you're unsure:
You can see the time in the upper left of the board index page. If it's wrong, click User Control Panel just above it. Then click the Board Preferences tab. The settings for the time are on this page. Change them to suit. If it was previously correct, you should be able to just set "Summer Time / DST in effect" to yes. When you've finished, click submit at the bottom. You'll get a confirmation message and then you will be forwarded back to the control panel. If this panel is new to you, now's a good time to have quick look and change anything.
Hopefully now when you look at the clock in the upper part of the index page, the time'll be correct. If you're having any issues with it, you're welcome to PM or e-mail me (thewebmaster@hinckleyrccc.co.uk).
