You anything to do with politics, if not then your wasted.
Supporting existing classes
Richie
Re: Supporting existing classes
Gazza
Gosh for a simple car its caused way to much troble i might just stick with brushed standerd v12! simple but fun!
And run 13.5 in a different heat this will be modifyed mardave's and keep the two apart!
Yea richard you could say that LOL
Been on committee's on model car clubs most of my life . . .
so I know exatly what happens and its so funny as the mardave has come round again been here so many times its unreal and the result is always the same . . . . FOLDS
remember in life to K.I.S.S. . . .Keep It Simple Stupid But alas the younger generation seem to know better I remember Months ago to K.I.S.S this topic with Standard and Brushless class only then it was to be called modified and now it wants to be called the GT class
So Yea I find it very funny and LMAO at the comments that fly around I can only advise people not put into force the do's and dont's
We have now found out that the Mardave Brushless Goes like a bullit
And infact the power/ speed / torque needs to be turned down so it handles good enough NOW Craig and James fit wider rear tyres on instead and still loose out so they not learning to well are they . . .
if it wont go around a corner at that speed then you need to slow down not go faster with bigger tyres you crash out take someone elase out and still loose whats the point hence the F4 class
Any way I'm running this Saturday with full AFTERBURNER so dont stand to close to my rear
The question gazza is Is it brushed or brushless??
Hell no. . . Nick
I 'm not in to kids battery stuff when it comes to planes
http://uk.youtube.com/watch?v=1IXQVh5IbHc
Turn ya sound up and Listen to them engines roar
hehe cool
But dont you melt my body shell when your flying low!
(urmm driver's on the rostrum duck gazza'z clipped the corner and has took off over)
Well, if Craig Races his V12 with the 'Sensorless' Mardave Brushless System again, this Saturday, I'll run my Mardave with my 'Sensored' Speedo/10.5T Motor as an experiment...........if the 10.5T ends up being faster(which is doubtful), we can then eliminate this from the Debate...............if it ends up being equal to the Mardave System, then I propose we should consider/have the following(sensible)Rules for a Mardave 'GT' Class :
1000g Weight
Std V12 Suspension Front & Rear
Aluminium or Carbon Fibre Chassis
Fixed Axle or Diff
Std Width Wheels & Tyres
ABS or Lexan Bodyshell(No 12th Pan Car Shells)
Any Brushless Speedo(as long as it has Reverse)
Mardave 'Sensorless' Brushless Motor or 'Sensored' 10.5T Motor
Unless anyone disagrees?
1000g Weight
Fixed Axle or Diff
Its a shame i can not make it saturday if i could i would race my brushless system too just to try it
Dean in a word. . . Nailed it . . . .
On hang on . . . . . and 27t and 19t and. . . . . . . . . . . .
. .LMAO
Post removed
Ditto
CORRECT
Basically out the box mardave g1. . g2 forward reverse blah blah some where on this forum will have a look 4 ya
MARDAVE STD CLASS(BRUSHED ONLY)
1 1000g Weight Limit
2 mardave suspension and mardave wheels
3 Std Aluminium Mardave V12 Chassis
4 G1/G2/NEW G2 Motor
5 Any ABS or Lexan Bodyshell by Mardave or Kamtec(No 12th Pan Car Shells)
6 Any Forward & Reverse Speed Controller
7 solid axle or Diff
8 Standard width tyres
Basically what most people run now
