I have to admit, the White/Red painted Wooden Discs do make the Track look really proffessional looking & were'nt really a problem when they were first made/fitted to the Track.................since then though, we've had the introduction of a 12th Pan Car Heat, which obviously runs slightly lower Chassis's & Foam Tyres, making the Wooden Discs unsuitable, specially as the Discs are a good few years old now & have quite alot of sharp edges/chunks missing out of them!
One of the main reasons why I dont run my 12th Pan Car anymore, are the Wooden Discs, as I cant justify paying £15 on a weekly basis for a brand new set of Foam Tyres, due to them being 'chunked', after rolling over one of them.
Martyn is right about the 'rolling on the roof' situation though, as I had a habit of rolling my Touring Car on its roof, due to getting on the power too early, while running over the Disc............I've recently managed to stop myself from doing this
I have to say though, I still prefer the 'flappy' corner idea, as you can get a tighter line without any problems........whatever Class your in! I also find it easier to see where the corner ends(specially if there in White) & even if you do hit them & get your Car stuck, you can usually use abit of throttle, bounce off it & free your Car without being Marshalled!
I noticed that we've had a couple of 'flappy' corners added to our Track recently, but unfortunately they've been made to short, making them have no give, so when a car does occassionally collide with it, they get wedged underneath it(12th Pan cars) or catapulted on their roof(Mardaves & Touring Cars).
LONGER FLAPPY CORNERS REQUIRED!
