WORLD RECORD ATTEMPT
Hey fellow r/c car enthusiats, i have a 1/18th scale car and was hoping to achieve the maximum top speed possible. I currently have a c4 9200kv motor running on li-po batteries. It is a 4WD system as I have utilised a belt attached to the gears to drive the front wheels. the shell i use is of a lamborghini and the chassis is also custom made from carbon fibre to make it light as possible. could anyone give me some guidance on how I can improve this set up? thanks! any advice will be much appreciated!
Gary K
- Name: Gary Kirkpatrick
- Car: Xray T2'008
Re: WORLD RECORD ATTEMPT
....just in case you wern't sure what you were up against
http://www.trakpower.com/index.asp?page ... lletin.asp
