Rich Pacey wrote:We would need to look at capacity issues. It gets really expensive when you start dictating what can and cant be used.
I recon 90% of mardaves racers at HRCCC run 4300.... A limit lower than this would render most of us ineligable.
Yea its also expensive if WE ALL gotto get LIPO and a charger
But dont forget thats just your club others may run other cells and you could be the minority
Ok so lets limit it to 3300 cells as they are on e bay at £9.00 a pack
http://cgi.ebay.co.uk/New-Battery-Pack- ... m153.l1262
warr2 wrote:Mardaves run on 4 cells or 4.8V total.
Lipo gives 7.4V (2 cells of 3.4V) so is roughly equivalent to 6 cell.
Just found this on the forum
"ELECTRICS
Any make of servo, servo saver or track rod ends may be used on the cars steering system.
Any type, make and capacity of speed controller may be used providing it includes reverse.
Cars to use four cells only, cells to be sub-C sized cells only, with a nominal voltage of
1.2 volts per cell, cells to be Nicad and Nimahs.
Well that clears that up . . .
LI-Po's are out
So what we all rekon then no limit or stick to 3300 or 4300 etc
I guess the organiser better jump on this soon as it gives us 4 months to save up for batterys
