gearchart. com
Posted: Sun Dec 14, 2008 12:35 pm
by WARRENRYAN
Filling in some of the boxes on gearchart.com the other day when i came across the saying transmission ratio not sure what that is
Re: gearchart. com
Posted: Sun Dec 14, 2008 5:23 pm
by JamesG
I should imagine this is the internal ratio of the gear box
Re: gearchart. com
Posted: Sun Dec 14, 2008 5:37 pm
by warr2
I you're running 1/12 or mardave the answer is 1.0. ( but then you should be more worried about rollout than gear ratio anyway as correct gear ratio changes with tyre size)
If you're running anything with a gearbox transmission ratio = no of teeth on the diff gear divided by no of teeth on the small gear on the shaft with the spur gear.
Re: gearchart. com
Posted: Mon Dec 15, 2008 10:07 am
by WARRENRYAN
Got it now thank's.
