tweak board for 1/12th
WARRENRYAN
I'm not a brummie I'm a Yam Yam!
Post by WARRENRYAN »
Hi all. Was looking on the web last night when i came across this tweak board for a 1/12th or a 1/10th tc. I have been asking around for a 1/12th set up board for a while now but not had much luck. It seems like everywhere you look its allways 1/10th tc set up boards. I am very intrested to buy one of these tweak boards so if anybody has one knocking about let me know how much you want for it. If you type in unity tool inc you will see the one i,me after. the seems to be $147. which is about £70 i think.
IBEXMotorsport
Car: Schu Mi5 / Supastox
Re: tweak board for 1/12th
Post by IBEXMotorsport »
WARRENRYAN wrote:Hi all. Was looking on the web last night when i came across this tweak board for a 1/12th or a 1/10th tc. I have been asking around for a 1/12th set up board for a while now but not had much luck. It seems like everywhere you look its allways 1/10th tc set up boards. I am very intrested to buy one of these tweak boards so if anybody has one knocking about let me know how much you want for it. If you type in unity tool inc you will see the one i,me after. the seems to be $147. which is about £70 i think.
You need to add the link, as know one knows what your talking about.....
RP
Rich Pacey
WARRENRYAN
Hi rich. if you go on to google and then type in unity tool inc and then click on the second one down you will see what it is.
Car: TOP Photon
Post by Dale »
Hi Warren,
I have a tweak station you are most welcome to borrow anytime. I assumed the 1/10th or 1/12th ones were the same.
If you are looking for a set-up station, then I believe these are specific to scale.
WARRENRYAN
Hi dale yes i would very much like use your tweak board if i may. I have sent you a photo over by phone showing you the tweak board i have made. Used it today with the pan car lined the wheels up and tried it out. The car went pretty straight believe it or not so i'me really pleased my FRANKINSTIEN board worked. Hope you got the photo and see you in 2 weeks.
