Help setting up a brushless esc
Posted: Fri Aug 12, 2011 11:38 am
by Hail Ming
Hi Folks,
OK - I've given in and decided to try a brushless set-up.
From my observation of the buggies - a 6.5 motor is too much for Hinckley, hence my decision to go with a milder motor (less is more). I've gone for a Hobbywing 120A 1S esc (similar to the Speed Passion) with boost etc. and a Speed Passion Ver 2.0 Ultrastock 11.5 (fixed endbell timing).
I'd be grateful for any advice on gearing (FDR) and general esc set-up. What I'm looking for is a set-up that will be controllable and smooth in the in-field, with a blast of speed for the straights. I know Martyn's RB5 runs well with his 10.5 and a small amount of boost.
Re: Help setting up a brushless esc
Posted: Fri Aug 12, 2011 2:03 pm
by BazzerH
Hey James, this is a pretty handy page for fdrs. As always go on temps as a final guide to fdrs but with small amount of boost these figures aren't going to kill a motor
http://www.teamnovak.com/tech_info/brus ... aring.html
Posted: Fri Aug 12, 2011 2:53 pm
by Hail Ming
Cheers Baz,
That should help with the FDR, but I'm still after some help with the esc settings i.e. good starting points for boost, timing etc.
Posted: Fri Aug 12, 2011 8:56 pm
by lapper cr2
Hope this will help you matey i run speed passion 6.5 and speed passion lpf speedo i know you stated your motor was not 6.5 but these are my settings,
DRRS Level 1 this setting goes to Level 9 i would only go to Level 2 for track size of Coventry and this setting changes the punch at low speed.
DMTS Timing Level 6 (18.75) this setting goes to Level 8 (26.25) this setting gives more power for straight line but also makes the motor overheat at the higher end of the timing.
I find this to be best for myself as i find it mild at the bottom and good speed on the straight but also keeps the motor temp mild also but gearing plays a part also as you will know with the 6.5 (78 spur) i will run 22t or 23t pinion dependant on size of track.
Anyway matey hope this has helped a little i will be at the track tomorow if you need any help come see me. :n1 Lapper.
Posted: Fri Aug 12, 2011 9:29 pm
by Hail Ming
Hi Mark,
That's great stuff - I'm not there tomorrow, but I'll give it a try and see how I get on.
