I only run 40 timing and 15 turbo at the moment. Will try 55 timing and zero turbo and see what it does.
MeBeMikey wrote:Tried the turbo ramp in three...brill on fast very high grip tracks but on normal grip to no grip it's not worth it. Point 2 seconds faster on high grip. Back to 2 for Hinckley, if I ever use turbo again.
Last night I set my car up on 50 timing and 8.0 drive ratio. No turbo added. Boy was it a lot better and it was only 5 degrees timing less than when I ran turbo. No more was I on and off throttle so much with the turbo kicking in. Motor came off at at the hottest at 62deg. Some races i was even in the low 50s. In the final I was trying to catch Dean with his new LRP SXX Stock Spec v2. Man that esc is smooth. I even dropped my throttle minimum to 5 to smooth my Tekin out but it made no difference. So i think it must be my ratio causing so much torque before the timing kicks in.
Saturday, I'm trying FDR of 7.6 and no turbo. Basically, 21/84 in an Xray t3. I'm sure it will be no problem. I'm thinking I might end up around 7.25 22/84.
Btw: I was only catching up to Dean cause his battery gave up the ghost last night. And i thought my driving was getting better.
