Supporting existing classes
Re: Supporting existing classes
Hi Guys,
To clarify and end this forum:
Standard Mardave class which will be silver can or 27t.
Modified Class - 10.5 t or Mardave brushless.
All cars should run to 1000g and have 4 cells (no lipos).
Hopefully this is the end of the matter and we can now go back to racing.
Thank you dale
*wait's for postie to deliver brushless system* hopeing it arrive's before saturday
Rich
- Name: Richard Ninness
- Car: T2 008, X-6², V12
With regards to the 27 turn stock running in with the G2's, it would be ideal (although maybe unlikely) if people could turn the throttle settings down as they are quicker than a G2. I think the idea behind allowing the 27t was so that the maintainence and consistency of performance is better than a G2, and there isn't a need to buy a new one every couple of weeks.
Also, is the mardave diff allowed in the brushed class? With the use of the kimbrough spurs?
Cant see why notRich wrote:Also, is the mardave diff allowed in the brushed class? With the use of the kimbrough spurs?
There's not much difference between running a diff or a well set up standerd axel'd car
Hi Guys,
I believe our stance on this is that if it is available from Mardave then I think we are ok, but when we discussed this Mardave did not have one, so my suggestion would be not to run until we clarify this.
I cannot stress the importance of ensure we are running within the ethos of this controlled class. We have always said we want to support Mardave, so if it is not readily available from Mardave it is not allowed.
Dale wrote:so if it is not readily available from Mardave it is not allowed. Dale
Ok Dale so just to clear that one up Mardave do do a diff and its
Part No V12D The Diff is 32dp £16.95 48dp £17.95
So I woud Decipher your comment as YES to alow into both class's
Could the on site mardave shop stock the diff? as i dont fancy paying for postage
thank's nick
thank's nick
You taking the MICK. . .stox217 wrote: as i dont fancy paying for postage thank's nick
You. . . who buys from Hong Kong on ebay and that postage is how much
well strictley i did not buy it from Hong Kong i got it from a fellow racer who deliverd him personally
- deaks
- Name: Scott Deakin
- Car: T2 009
My wife read this and disagreed. She said I'm often full of air and it's got a very distinctive aroma!Dale wrote:Actually those cobs have a lot of air in and are easily consumed at pace. Scott on the other hand is not full of air..................he is full off........<<end of transmission>> lol!
She would further like to add that 'Farting on her leg in the middle of the night' is one of my many varied talents....
"Sponge and a bit of Jam"
Hi guy's. If i was to race my mardave again' as well of sticking to 1/12th pan. then would i have to stick in to it : Any make of brushless combo and also run on a 10.5 motor? to keep up with the mardave system.
ANy brushless system in a Mardave has to have forward and reverse (i.e. the Nosram system you have).
We will now allow a forwards only system, which should now result in a more level approach.
I think you might have a slight problem here dale? Im in the progress of buying a forward only esc' coz the reason is you do have more power to your drive then one with reverse. Have been told that' thats a fact! by many other drivers now if you have mardave drivers with the nosram combo ie: (evil esc dragon motor) and someone has a (matrix esc and the new nosram motor which is the one you have ' then they do not stand a chance. I know coz i have been through this my self.
Hi Warren,
On saturday it was agreed to run 10.5t or Mardave as they had the same power, however to run in the modified class we are asking for ALL speedo's to be forwards and reverse.
I know for a fact that forwards only speedo has more power, however, with a 10.5t this is agreed as being on par with the Mardave system.
My advice is to run the Evil you have!
