Hi all,
Dale(Club Chairman) has just Confirmed with me that the Hinckley Club will have 50 Sets of Sorex 28 Tyres/Wheels In Stock for next Saturdays Club Meeting - 24TH SEPTEMBER
The usual Shop Price on them is £28 per Set now, but HRCCC will be Offering them to all Club Racers for a Special Price of £25
See you all nextweek!
SOREX 28's BACK IN STOCK AT HRCCC
- Name: ryan
Re: SOREX 28's BACK IN STOCK AT HRCCC
Any idea if we can get loose tyres rather than wheel mounted?
- Ian_Smith
- Committee
- Name: Ian Smith
- Car: Schumacher Mi4LP
No, the club only supplies the pre-mounted Sorex 28's. In my experience there is little point in getting just the tyres because they cost about £10 a pair, and invariably the actual wheel tends to suffer damage (cracking at the Hex, or even a slight warp) and trying to get the old tyres off the wheels is not usually terribly successful anyway.
Schumacher Mi4LP / Hobbywing Justock / Speed Passion V3.0 17.5
"Speed is nothing without Control" - wish I had just one of 'em!
- Name: ryan
Thanks for the reply Ian, unfortunately i run a old yokomo car and it's seems that the majority of wheels foul the arms with the webbing. I have a new set of 0 offset yokomo wheels that don't foul the arms ( very little webbing) but it seems sorex 28's are hard to find loose,any of these tyres any good on our carpet surface?
TakeOff CS22, CS-24RP,CS-27RP,CS-30RP,CS-36RP or Powers PJ22.
Failing that if anyone has some decent nick used loose Sorex 28's let me know .
Hi Ryan
I'd go for either the 30 or softer 27 compound - depending on how much grip you think you need with the Yokomo chassis. Most of us run 32 compound Sweeps in the Quick Silver class - in fact the TT01E chassis runs better on this harder compound tyre as it's less likely to grip roll.
