Hello all,
I have got some shock fluid and i dont know which one goes on the front and back of the shock absorber.
They are different density, one is 25wt and the other 30wt, which one goes on the front and for the back.
THanks
Shock Fluid For mad rat Buggy
Re: Shock Fluid For mad rat Buggy
Hi Michael,
You'll want to use the thicker oil (i.e. 30wt) in the front. Although you might want slightly thicker oil all round - perhaps 35wt in the front and 30wt in the rear.
Ah ok thanks!
I think i will just stick with 30wt on the front and 25wt on the back for now.
Maybe when i run out of the oil i got i will buy a 35wt and put it on the front, and 30wt on the back.
