On-board camcorders
- Hail Ming
- Name: James Carroll
- Car: MM & X2 Evo
On-board camcorders
Hi Guys,
Richard and I were experimenting yesterday with an on-board camcorder - the results were pretty impressive. So impressive that as soon as I got home I ordered two. I'll being editing the footage shortlly and will add a link to this thread.
If anyone is interested in an on-board camcorder, the one we were using was a MD80 mini DV; widely available on Ebay for about £12 (inc shipping). In addition to the camcorder, you'll need a micro SD card, but these are really cheap.
Watch this space for the footage...
Cheers
Cheers
- Hail Ming
- Car: MM & X2 Evo
Re: On-board camcorders
YouTube link as promised...
http://www.youtube.com/watch?v=EmTTR536pdw
Some of the quality has been lost when uploading onto YouTube, but still entertaining.
Cheers
Cheers
- Name: conor
can i stick one on my tourer
- Experienced Member
- Name: Rich Pacey
- Car: Schu Mi5 / Supastox
Excelent quality.. better than that i managed some time ago.. Still suffers from the same old problem though..The angle is not wide enough / the car changes direction to quickly..
If the quality / frame rate is good enough, then maybe these shots would benefit from being run at half speed?..
Rich Pacey
- Hail Ming
- Car: MM & X2 Evo
Hi Rich,
Good to hear from you - cheers for the comments. Quality would also be improved if we'd cut a hole in the windscreen. Not sure what we could do about the angle, but the frame rate might be worth looking at.
Cheers
Cheers
- Name: Rich Pacey
Hmm. The windscreens look clear from a couple of feet, but of you study them, they can be a little opaque, especcially if yours is particuarly "orange peel" effected..
It seems that this camera is a MUCH better option than the wirless spy camera I tried some time ago. Can you confirm that this also records Sound. Not managed to watch you tube with sound yet..
If it does, I'm gona seriously consider 1 or 2 for my motocross..
Rich Pacey
Hi James,
Great post - would like this on the front of the website and more if possible!
Richard Pacey - a blast from the past - are we going to see a Return to Hinckley perhaps?
- Name: Rich Pacey
Hi Rich,
Sent you a PM.
Sent you a PM.
- Hail Ming
- Car: MM & X2 Evo
Sure thing - should be getting some more footage at tomorrow's meeting.Dale wrote:Hi James,
- Name: Rich Pacey
Iv'e just orderd my camera... Thanks for your help yesterday james. Much appreicated.
Rich Pacey
- Hail Ming
- Car: MM & X2 Evo
No worries Rich,
It was good to see you again - good luck with the new moto-x season.
- Name: Richard Ninness
- Car: T2 008, X-6², V12
These seem to be all the rage lately! I think they're a copy of the Muvi cameras which retail for about £50.
Bought one myself actually!
Anyone else looking to get one make sure you get a Class 6 memory card for it, anything less and you'll find that the footage 'skips' a lot.
- Name: Rich Pacey
These cameras record onto a micro sd card. The cards are rated by class. For a class 6 card, the minimum write speed of the card is 6mb/s. With a class 2, the rate is 2mb/s. You'll find with class 2 cards (for these cameras), the footage will skip, because the card can't handle the rate the camera is trying to write to it at. With a class 6 card, this isn't an issue therefore the recorded footage will be smooth.
Obviously the class 6 is a bit more expensive than say a class 2, but you can get an 8GB one for around 15 quid which is pretty reasonable!
Hope that helps
Hope that helps
