Who else is going to do this as i will need to hook up off a 12v battery or 240v mians but as i have not been there before i need a bit of advice as what i will need and set up for an x6
cheer's
Coventry's 2wd Regional
Re: Coventry's 2wd Regional
wot shocks r u running on the car ?
- stox217
- Name: Nick
- Car: V12
B4 thereaded shock's mate also its 4 gear and got i think 30wt oil in them
The 2WD Mid-West Regional at Coventry will be held on their Grass Track.
A good Starting Set-up for the X-Factory X6 would be :
SHOCKS(Associated)
Front - Piston 1
35W Oil
Blue Spring
Rear - Piston 1
30W Oil
Silver Spring
Coventry are currently holding Club Meetings every Thursday night, which gives you good Practice for the Regional Event at the end of the Month.
SHOCKS(Associated)
Front - Piston 1
35W Oil
Blue Spring
Rear - Piston 1
30W Oil
Silver Spring
- stox217
- Name: Nick
- Car: V12
well i have 30w all round andhave that set up so will try it thursday
(wont make it to coventery going on holiday on that date
- stox217
- Name: Nick
- Car: V12
Also what insert's do most run at hinckley & coventery?
Schumacher Blue Hard inserts all round... Eric usually has a good stock of them!stox217 wrote:Also what insert's do most run at hinckley & coventery?
Jon!
