A vote for indoor buggies.
- WARRENRYAN
- I'm not a brummie I'm a Yam Yam!
- Name: WARRENRYAN
Ok guy's  with little talk about having buggies racing indoor's and having peaple saying yes they would be intrested. Let's have a show of hands(responce) for how many would be intrested in starting buggies in the next indoors season.  And also the fors and against???
Re: A vote for indoor buggies.
Im against because of the lack of time its packed already as it is could be ran as a support Formula? incase there's not enough racer's??
				The mad1
- Name: keith jacques
- Car: associated b4
im definetly up for it and depending on how brandon gets on offroad he may well be doing it aswell
for, it means we will only have to have 1 car each for the hole season which will cut costs dramatically
against, erm cant think of any really
- Wacker2
- Name: Jon Seals(Wacker2)
- Car: TLR 22
im all for it... although it would need to be on foam tyres.
However, if the usual suspects (dean, gary and martin) decide to run touring cars again next indoor season then I will probably end up racing touring car myself... I need to race where the competition is.
Jon
Jon
I'm definately intrested in giving Indoor Buggy Racing a go at some point..........I'll make a decision on whether to Race Buggies, Touring Cars or 12th Pan Cars nearer the time of the next Indoor Winter Season, which is around September i think?
All I do know, is that I wont be Racing Mardaves again, as its been ruined by too many different Rules, regarding Brushed G2, Brushed 27T Rebuildable, Brushless 10.5T & Mardave Sensorless Motors, which has diluted the Competition in the Class
I've recently heard that theres quite abit of intrest in having a 10.5T Pro Stock Touring Car Heat for next Indoor Season, which is also very tempting
I'f I decide to run my Buggy, it'll be on Foam Tyres, Std Buggy Springs & the same Motor as I use in it for Outdoors.
I dont think rule's have killed the mardave class as there's usaly 3 good racer's on form every meeting which is fun
well it be fun to see how the next indoor meeting go's
				tomjgardner
Id allso be interestd, but I would want to run yellow mini pins and a 13.5/27t motor.
I would be up for it if was proper indoor off road with jumps but I don't think this'll happen as it's not fair on people wanting to run mardave and touring.
I will join in with running my buggy at the last indoor meeting of this season if I'm allowed to play with my 4wd and mini pins
You could easily put in one or 2 kick jumps and remove them for the other classes.
We've done this in the past.
I'd like to run buggy, but not interested if it goes the foam / touring car spring route.
Using touring car springs is another thing which I believe contributed to all the issues we used to have with wishbones.
				The mad1
dales already said defo standard shock setup   i have to admit id prefer rubber rather than foam but i am easy il do both
				jayst
- Name: jamie cheshire
- Car: T D . 210,410.408
i will do it if only on mini pins and outdoor motors
						- WARRENRYAN
- Name: WARRENRYAN
Ok! If buggies where to start indoor's then here are 3 category's to choose from?
1)...buggy with standard suspension....any motor limit..................
2)...buggy with standard suspension...27t/13.5 motor limit..........................foams or rubber...
3)...buggy with standard suspension...19t/10.5 motor limit............
please state the number you would like to race in and then the tyre choice ie: (1/rubber)
(1/foam)
That way then everybody would know where they stand when entering the buggy heat.
 (1/foam)
				tomjgardner
From the list i would say 2 rubber for myself,  But I would not pigeon hole this to much as I might put people Off and that will be then end of it.
None of the above!
Buggys are far more fun off-road!
