I am trying to help someone out on getting their B3 up and running for the summer season but I am totally unfamiliar with Associated vehicles, won't be for too much longer. My friend has an 8.5 Novak non-sintered motor and will be running it on 6 cells. I would like a conservative gearing recommendation as this is the first brushless system my friend has had as I believe they are more use to 27t motors. His spur gear I believe is stock size but what ever spur gear and pinion combo you give me I will adjust only the pinion accordingly.
TeamBritUS
B3 Gearing
B3 Gearing
Re: B3 Gearing
Never run an 8.5, but for a 6.5 you'd want to be geared approx 10.2 overall.
Internal ratio of a b3 is 2.4 so assuming it's the standard 81t spur gear, that would be a 19t pinion.
For an 8.5 you'll need to be geared a little bit higher, so if it were me I'd try a 22t pinion to start with.
Re: B3 Gearing
Never run an 8.5? Now that depends on circumstances.warr2 wrote:Never run an 8.5, but for a 6.5 you'd want to be geared approx 10.2 overall.
Thanks for the info. Will pass on to him the pinion choice.
Re: B3 Gearing
"Never run" as in "I've never run" not as in "Never should be run"
