Xray T3 2011 spec Set-up
Posted: Thu Feb 03, 2011 6:43 pm
Built car to kit spec but did this to it:
1.5 camber all corners
.5 degree outward toe front
3 degree inward rear
H-links front and rear (tames the sensitive steering)
One hole rear hubs
Xray stock plastic shocks
Front mounted center, rear mounted one down from center
Kit oils 350wt
Droop front 6, rear 5
Ride height 5.5 fr to rear
Ardent changes:
Xray aluminium shocks w/3 hole 1.2mm holes
500wt MuchMore oils
One hole rear hubs
Kit oils 350wt
Ardent changes:
500wt MuchMore oils
