Need Help With Gearing Mardave Brushless and 27t Motor
Car: Xray T3 2011 spec
Post by MeBeMikey »
What gearing are you guys running out there? I just got the Mardave Brushless Systemand a Reedy Stock Star 27t motor for the standard class. I would like to know how to gear them both. I have always been racing a G2 motor in the standard class not knowing I could also run a 27t motor.
Any help is greatly appreciated as I have been told conflicting numbers.
See you guys this Saturday! :D
Team BritUS
Richie
Re: Need Help With Gearing Mardave Brushless and 27t Motor
Post by Richie »
Hi Michael
This probably won't help, but I gear my 27t stock motor the same as my G2, and just adjust one pinion either way as fine adjustment, depending on how its running and the track.
Post by MeBeMikey »
Thanks for that...
Brushless I will be running 15/48
27t I will be running 13/48 or 50.
stox217
Car: V12
Post by stox217 »
Il try a 27turn motor using 15/48 the same as i gear my g2 motor's
Richie
Post by Richie »
Seams Reasonable. Whats the worst that can happen either its a bit slow and cool or still a bit slow and hot, the beauty of 27t stock with 4 cells is their virtually indestructible, I havent been able to cook one yet, a light skin is the worst case senario.
